Turboshiftaru Posted June 24, 2017 Posted June 24, 2017 Can someome please help, im really trying to find out where the hell this oil leak is coming from, it can either the rocker cover or an oil leak from somewhere underneath. I get a really bad smell if i drive hard then it starts smoking a lil a white smoke it looks like oil please help
kershaw-330s Posted June 24, 2017 Posted June 24, 2017 Could be a rockercover gasket , have you taken the leafs off and had a look , best thing to do Is clean all the oil off best you can the go for a lil drive , then look may help you locate the leak
Turboshiftaru Posted June 24, 2017 Author Posted June 24, 2017 32 minutes ago, kershaw-330s said: Could be a rockercover gasket , have you taken the leafs off and had a look , best thing to do Is clean all the oil off best you can the go for a lil drive , then look may help you locate the leak Looks like it is the rocker cover would you know much that would be to repair that leak
stants Posted June 24, 2017 Posted June 24, 2017 Gasket kit is about 25-30 for both sides and half moon's it's a bit of a pain think I paid about 100 quid for mine doing (both sides)  Sent from my SM-G930F using Tapatalk  Â
Scoobyghost Posted June 24, 2017 Posted June 24, 2017 Gasket kit is about 25-30 for both sides and half moon's it's a bit of a pain think I paid about 100 quid for mine doing (both sides)  Sent from my SM-G930F using Tapatalk   Or you can avoid being a !Removed! and save yourself labour cost [emoji23] [emoji23] [emoji8]  Easy enough job to do. Take a few hours if it's your first go. Ideal opportunity to do a plug change too if it's coming up for a service.
stants Posted June 24, 2017 Posted June 24, 2017 Gasket kit is about 25-30 for both sides and half moon's it's a bit of a pain think I paid about 100 quid for mine doing (both sides)  Sent from my SM-G930F using Tapatalk    Or you can avoid being a !Removed! and save yourself labour cost [emoji23] [emoji23] [emoji8]  Easy enough job to do. Take a few hours if it's your first go. Ideal opportunity to do a plug change too if it's coming up for a service.   Or you could look at it this way, and you could stop being a tight !Removed! and pay someone else to do it if you don't fancy removing the washer bottle, Battery, dipstick tube, airbox and other bits that get in the way before you've even got to the rockers,  Plus the reg number may not necessarily bring you up the right parts, we tried 3 different gasket kits before we had a match, so if you take it to a mechanic least they will be able to get all parts on sale or return basis and not have to possibly wait 3 days for new ones to turn up.  I could have done it but hate gaskets and getting them seated so didn't mind paying for someone to do it for me  Sent from my SM-G930F using Tapatalk  Â
Scoobyghost Posted June 24, 2017 Posted June 24, 2017 You mean actually spend my money? 😂 Try to avoid that as much as possible. Even if it does mean a full swear jar, which in its own way is saving money.
stants Posted June 24, 2017 Posted June 24, 2017 Just think of all that cash sat outside that doesn't move anywhere 😂 If you are doing a diy job may as well do the plugs at the same time if don't know history of car, No point putting old ones back  Sent from my SM-G930F using Tapatalk  Â
Turboshiftaru Posted June 24, 2017 Author Posted June 24, 2017 7 minutes ago, stants said: Just think of all that cash sat outside that doesn't move anywhere 😂 If you are doing a diy job may as well do the plugs at the same time if don't know history of car, No point putting old ones back  Sent from my SM-G930F using Tapatalk   Wait does the plugs have to come out when i change the rocker cover gasket
Sandals Posted June 24, 2017 Posted June 24, 2017 4 hours ago, Turboshiftaru said: Wait does the plugs have to come out when i change the rocker cover gasket No but you need to remove the coil packs... if the plugs haven't been done in a while, you may as well change them as they are accessible at this point. I did it when i changed my gasket last year
Scoobyghost Posted June 24, 2017 Posted June 24, 2017 Does help if they're out of the way too when trying to put the cover back on.
stants Posted June 25, 2017 Posted June 25, 2017 Most gasket kits come with new spark plug seals too  Sent from my SM-G930F using Tapatalk  Â
