Hi all
I have just sold my scoob so will soon be listing all the parts from the forged engine build I was in the process of doing on here and scabbynet
there will be
New unused fully built forged ej25 bottom end with closed deck insert/conversion with killer b oil pickup and sump fitted, brand new crank, rods, 100mm pistons etc and 1.7mm headgaskets, arp 14mm head bolts etc etc
Wrapped williams headers used
Wrapped harvey uppipe used
3" turbo back polished full exhaust system used
Used hawkeye sti heads single avcs with 3 angle valves, with new valve guides and seals
kelford beehive valve spring kit new
water pump new
white line anti lift kit new
loads of parts from import car parts, gaskets, ceramic pulleys, crank sprocket etc
more stuff that I can't remember at the mo
if interested drop me a mail
mike
will get some pics up soon
2 hours ago, Piggysniffer said:
Hi all
there will be
water pump new
white line anti lift kit new kca359
mike
On 11/13/2017 at 12:18 PM, Seminole81 said:
Why you sell it?!
And also how much you looking for filth at bottom end 😬
coilovers/spring?
How much for the short block?
This topic is now closed to further replies.
