Fuel saver info screen
On my late 15 reg, with stop and go, the time stopped and fuel saved screen only showed whilst stop and go operating. Since yesterday’s service, it shows all the time, except when other messages come on (door open, low fuel, etc). Anyone else had this happen, after recent service? Not annoying, but got used to the empty box under the fuel gauge 😂
They may have done an ecu software update while it was in for service that could possibly change the dash info set-up, all the newer trucks at work are always having to go get ecu updates
On ours (2017) the display between the clocks is toggled by using the up and down arrows on the steering wheel, just below the indicator stalk. This can be set to just show stop time and fuel saved constantly, rather than just when the engine cuts out.
Try flicking them when the ignition is on to see if it changes, as they may have been knocked during the service.
Cheers for that. So many different knobs and switches, doing all sorts of odd things! Will get my neighbour’s ten year old to sort it 😂
