Dash lights all lit after start
I recently removed dash on 2006 hawkeye sti because of leaking heater radiator
Since building the dash back I have eng management light on,airbag,diff temp and abs even after starting it will not go off
The battery was bad so I replaced it but same scenario
Is it possible I've missed a plug and if so where? Or do i need it plugged in to a diagnostics
Would help diagnosis if new if ecu actually triggered those codes thus lights or if just goofy plug/wiring error in your dash assembly causing lights come on.
I suspect harness plug seating issue and side effect is these warning clusters acting as earth route perhaps .
As you done the repair only you have full insight to areas of potential damage physical or from water that might of occurred .
