Hello everybody I have a subaru bugeye 2.0 was driving fine till lost all power and stopped changed coil pack and cam sensor petrol pump is fine coils 3 n 4 spark but 1 n 2 don't spark at all any ideas in need of help thanks
Nah no error codes
I've changed crank sensor not cam sensor
You'd normally loose spark on all cylinders if crank or cam sensors were at fault .
Are you definitely getting spark just on the 2 front cylinders? .
Have you tried swapping coilpacks from front to back to see if the misfire changes cylinders ?
Main Engine loom plugs (either end near battery and boost solinoid) and earths making a good connection ?
Spark plugs in good condition?
Yeah defo just sparks from 2 cylinders also tried changing coil pack around ,spark plugs are new aswel car was driving perfectly fine all of a sudden jumped forward a few times and all power just went
Might be worth whipping the covers off and checking the timing marks, just in case the belts slipped due to a worn tensioner.
Did you use the right grade plugs ,ngk heat 6's for standard or heat 7's when modified.
Definitely plugged the coilpacks in the right way on each bank .
With 2 cylinders not firing at all ,it's strange you've not got any codes tbh .
Yeah ngk 6s someone suggested might be ecu due to no codes showing but apparently there's no chance the ecu going it's rare on subarus apparently next thing I'll have a look at is timing thanks for the help
