Brake pads!!
Hi, im hoping for some help to find the right brake pads for my 2010 outback.
The brake system is tokico, and i find alot of pads for my front axle but absolutely none for the rear axle.
Im hoping maybe someone here have a part number or the number for some replacement pads that fit my rear axle.
Thaks in advance
/Christian
Skickat från min SM-G950F via Tapatalk
Thanks for the information jay762, when i look at the caliper on the rear axle it says tokico on the side of it. Will the akebono pads fit anyway?
ADS74223 ! compare visually and measures length/width
length 110.4mm  width 37.5  thickness 13.8
No dont go for the Akebono if it says Tokico - check MrB's info first 👍
