Flat Battery - Possible Solution
One possible solution to my flat battery problem is to have a solar panel on the dash when the car is parked this would trickle charge the battery. Normally this would plug into the 12v outlet however this is only live when the ignition is on. Any ideas how I could get round this?
I would make your dealer get to root of issue rather than patching it up with solar charge panel ...
If going trickle charge you ideally going want separate wire run direct from battery with inline fuse .
