Karl99 Posted March 30, 2020 Posted March 30, 2020 I have a 2004 Subaru Impreza witch I’ve been told has a misfire but just wondering what could be the problem I’ve tried spark plugs and ignition coil but still has the problem so I got a scanner for the car and it’s shows that this is the problem but Don’t know what this means
Scubzjames Posted April 22, 2020 Posted April 22, 2020 Hi, what scanner and app are you using? ThanksSent from my iphone using Tapatalk
larry Posted May 8, 2020 Posted May 8, 2020 I had a similar problem with my car and it was down to the ignition leads being in there wrong places.
Neil Posted May 10, 2020 Posted May 10, 2020 First thing is note the codes down and then clear them, then see if they come back on, they dont seem to point to a misfire. If you've changed plugs, leads, coil make sure you have firing order correct if so so try compression test
