New XT Turbo Coupe owner
Hi all
Just about to become an XT Turbo coupe owner for the second time after owning one in the early nineties.
Back then parts were scarce and I'm guessing it hasn't got much better 30 yrs on 😎.
Wondering if there are any other XT owners on here?
Car should be arriving tomorrow hopefully so it will be over the pit and given a full assessment then.
They are pretty rare, how many left are showing 3 registered on the UK roads.
Hopefully this will be number 4
Not a great start unfortunately.
car didn’t want to leave the transporter as the osf brake was locked up.
Once I’d removed the caliper and found the dust boot mullered I could roll it over the pit to drop the oil as it was way over the upper mark.
Thats when it got worse.
So I went for a pint
I'm guessing it's heads off, sump off if it's do able, turbo out and check for damage?
Guessed that's why it hasn't run in 2 years and why there was no battery with it.
8 hours ago, Tidgy said:
tbh i suspect you will need to give the whole engine a strip down, new bearings etc etc
Thanks I was thinking that would be the most sensible thing to do.
Might give Subaru a ring and price a full gasket set up.
Speak to import car parts. Subaru dealer network will prob be useless.
Thanks I'll look them up.
Went to pressure test the cooling system today and was a complete fail.
I put 5 litres of water in the rad and it ended up straight in the sump,
Guessing this is hopefully a gasket failure rather than a cracked head.
Will hopefully begin the strip down tomorrow
A sound move 😄😄😄
So I've decided to pull the engine out to give it a good check over,
Am considering just replacing the whole thing In one hit, but unsure what would go back in its place with the minimum of fettling.
Any ideas ???
Second hand engine is just that, you may get a good one or you may get a bad one, if your planning on keeping the car I'd just bite the bullet and get it properly rebuilt, initial strip and assess will tell you what the current situation is and what's salvageable.
You’re right I was thinking the same.
A lift out and strip will be minimal cost.
  • 4 weeks later...
So I've found the culprit, it had spat a freeze plug in the RHS head.
Been replaced and gasket set arrived for the re assembly.
I've just rebuilt the oil pump and have cleaned just about all the oil galleries I can get to.
Sump is off with new paint drying. Plan is to refill with oil and spin pump with a cordless drill to prime system and blow through any  remaining sludge.
Once new seals have arrived from Japan I'll rebuild the cam towers, refit everything removed and drop the engine back in and fingers crossed.
Hi XT friends,
It’s great to see another XT coupe that has survived.
I have a 1992 auto that I’ve had stored for the last 15 years....
Does anyone know where I can get the car serviced?
Congratulations another one.
May be a good idea to start your own thread though so it's more visible.
Don't forget pics.
So I gave up waiting for the waterpump to arrive from Subaru and decided to put the engine back in.
Everything has been cleaned, degreased and had new gaskets and seals fitted.
Stuck a short video of the engine running on youtube.
