Carpet upgrade
I've removed my seat's and carpet completely from my car, I am looking at options, what would be the best way to go? Buy one online with matching part numbers, go see someone locally or make one myself. 2009 Impreza RX GH7
 a second hand carpet from a breakers would be much cheaper than new subaru . I'm not that clued up on hatch spec but bug/blob sti have a different colour carpet , so there might be the same for hatch (if you fancy a change )
Hi - I looked into this for my own, a breaker will be your first most economical approach (and where I ended up) Subaru had zero stock listed for the part number so I could not buy new even if I wanted to. Bespoke is great but you mentioned not wanting to put too much money into the motor due to changing in the not too distant future.
Note the foam and plastics attached to the carpet is part of it - you cannot buy any pieces individually.
WRX and WRX STI carpets and seats will fit in your motor. There are black and dark grey colour options that I know of - maybe more as I do not know what is in the blue models
Thanks, I have seen some wrx's at breakers near by I will check out, I do like the black but I might change my mind when I see them in person.
