Exhaust
Hi all
just had a new up pipe fitted to my gb270 as my other had a leak
now this one has been fitted something (up pipe/down pipe) is catching on the steering knuckle when turning and making an awful sound when turning mainly left,
anyone any ideas
Also today eml has come on and it seems to be running rough
could this be maf needs a clean?
P0171 - system to lean (bank 1)
thinking the lambda may of been damaged when changing up pipe Or gone faulty
thinking the lambda may of been damaged? Or gone faulty
fingers crossed
I would say, the primary concern here is the steering knuckle fouling the downpipe issue.
Iv experienced that sort of fouling problem when using cheapo brands. Your either gonna 1. have to marker Pen the area that touches, then take off the pipe and smack it with a hammer & put it back on & keep doing that till it clears, but you risk bending pipe. And it's a load of effort.
Or 2. get a quality branded pipe that fits correctly out of the box.
Then the running lean issue would be the next issue to sort out.
🤔I would just get a new oem sensor with a new quality brand pipe.
