Nimpy Posted September 7, 2021 Posted September 7, 2021 Hi Sure it's been asked a thousand times, but what fuel pump is recommended? Heard the Walbro isn't very reliable, is this right? Asking as it feels like the car is starting a bit when cruising at a steady speed, Al.ost like I am taking my foot off the accelerator a little then putting it back on. I wi change the fuel filter 1st, as I am not sure when it was last changed, but failing that the fuel pump was my next go to. Any thoughts ? Was looking at the hrc 290
Jay762 Posted September 8, 2021 Posted September 8, 2021 Given the age of your car it would not be a bad idea to replace both pump and filter. The stalling could be down to an electrical issue with the plugs or bad earth?? Are there any codes being generated? Check you hoses as well you may have a small leak somewhere Check this pump put as an option - allegedly built in the same factory as other branded pumps but I have had no issues with ICP service https://www.importcarparts.co.uk/parts-info?id=14254&cat=3678&sub=3680&sec=0&var=0&dc=&gen=0&searchKey=&searchPart=
Nimpy Posted September 8, 2021 Author Posted September 8, 2021 Cheers Jay. I haven't checked the codes tbh, I will though. I changed the plugs and leads as a 1st stop, maybe the coil pack could do with changing too. It is barely noticeable, but it is there, almost like a bit of fuel starvation, I'll order a fuel filter 1st off, then get a pump. I'll also check for any leaks, though there is no fuel smell, which is good. 1
Jay762 Posted September 13, 2021 Posted September 13, 2021 Keep us posted - If you are going to look at the coil pack itself maybe consider a stick coil conversion from the later models?
Nimpy Posted September 15, 2021 Author Posted September 15, 2021 Will do mate, not had a chance to look at it this week. I ls the conversion to stick coils awkward? Cheers
stuartie Posted September 15, 2021 Posted September 15, 2021 Hi mate the coilpack conversion is pretty straight forward, I managed to do it easily and I'm no sparky, I used this site for guidance, https://www.jamessimpson.co.uk/classic-impreza-new-age-coil-pack-conversion/ Hope this helps 👍 2
Nimpy Posted September 15, 2021 Author Posted September 15, 2021 Cheers Stuartie, I will have a look !
