mowog01 Posted September 13, 2021 Share Posted September 13, 2021 Hi everyone, Hoping for some wisdom regarding the above. I'm helping a friend (who isn't really a car person) to fix his 2001 Subaru Outback 2.5. We've ascertained that it needs a new lambda sensor, but I'm struggling to find a replacement. I can see there are two sensors going into the section of the exhaust that contains two catalytic converters. There is one that goes in end-on, and seems to run pre-cat. And there's one that goes in from the top, after the first cat. It's this one that is the issue - the car hesitates and splutters a lot, and won't rev, unless you unplug that sensor. My confusion relates to the following... The sensor that needs to be replaced is a four-wire sensor, but when I look on eBay for matching parts I only get three-wire sensors come back. What's all that about? Does anyone know what other sensors (i.e. from other cars) are a match, technically? I found one intended for various Fords and Volvos that looks identical apart from the plug. The only Subaru sensor I could find that has the right connector is this one - https://www.ebay.co.uk/itm/142804741377 - but that is not listed as matching this car, and is also described as a front sensor - presume ours is a rear sensor? I'll try and add some pics here so you can see what we've got. I'm pretty certain it's original as it was a one-owner car from an old couple, and doesn't seem to have been fiddled with. Would be very grateful for any advice you can offer! Quote Link to comment Share on other sites More sharing options...
Jay762 Posted September 13, 2021 Share Posted September 13, 2021 I would give Import Car Parts a ring - They have a pretty good handle on what will fit what Quote Link to comment Share on other sites More sharing options...
