Leaking door seals?
Can anyone tell me if you can stop rear door seals on a classic impreza from leaking  ?. Is there any adjustment on the glass runners (so as to increase pressure onto door seals)?. Thanks in advance
Not sure on your model but I saw a fix to a similar problem using rubber tubing that was fed down the inside of the door rubber seal to give it more resistance - can you do that?
Thank you ,do you know of any aftermarket ones as I need both sides, thank you for replying 😊
I dont know that - I saw a couple of used ones on ebay but I dont know if that is just running the risk of leaks still???
