Silicone hose
Anyone no where I can get a cheapish silicone hose to replace this one post-1928-139645759725_thumb.jpg
It runs under inlet think it's turbo to intercooler one thought I would upgrade it while it's off
That's the inlet hose I think mate try eBay
About 70 quid I think they are
Are they thought they might be cheaper can't see any u got a link
Try searching for "v5/v6 turbo inlet hose " a samco one will set you back about £200 but there's cheaper options.
if you intend to run higher boost than standard beware of dirt cheap ones , as they've been known to suck flat .
Ok thanks
Yep mine went flat and cracked
Pain in !Removed! to change
Think am just goin to keep standard one lol
If standard power it's fine mate
Yeah not doin much engine wise it's 280standard quick enough for me
Yeah long as it's a solid pipe will be fine they crack along the edge / join
Yeah it's solid like the look of silicone one tho will see might find a cheap enough one before engines goes in
Easier to do when engine is apart
Thinking that engines out for a good while till rest of cars done so might end up with one
