Posted
got a 1998 impreza awd 2.0 litre non turbo
wishing to eventually change the steering wheel
aware of airbag issue but any advice welcome at this stage testing the water listening to good advice of impreza owners who ve gone down that route in the past
appreciated
Posted
Did it in mine and very easy. Disconnect Battery, then on either side of the steering wheel are a couple of fox bolts which should loosen to take off the airbag off. Loosen but dont take off the 17mm (or 19mm forget which) Central nut to stop wheel smacking
you in the face., then with the nut still on pull the wheel lose, Then remove the nut and steering wheel Undo the electric connections and its off. Remember if you are using a after market steering wheel you need the right boss for the connections
Posted
mine is 1998 read the boss kit around these years is generic to all models thats a company selling them plus checked momo but that was to 1996
maybe someone can reassure / confirm this
do i need to attach a resistor to fool the air bag system with it removed
thanks
done lots of wheel changes but not air bag models
Posted
You either need to use a resistor or remove the bulb. Not sure what resistor though. And make sure the boss has the connectors for the horn or it will be a bugger to Wire.
Was my first car with airbag and is very similar just remember to disconnect the Battery.
Posted
thanks
seen the specific resistor for sale by momo but probably fleabay will have some
thanks for advice
Posted
also my impreza is 1998 2.0 litre sport awd
are subaru wheel boss generic through a certain year range
thanks for info
confusing checking compatibility charts
Posted
the horn doesn't have to be an issue if the wheel you really want doesn't have one as dash mounted button in reach of the drivers hand will pass an mot - the Antera wheel I have has two that you keep catching by accident so I disconnected them and had a small button fitted instead
Posted
thanks
ordered a boss kit and 3 ohm resistor so now going to sort out what steering wheel i want and do the mot first in a few weeks first then its full steam ahead on subtle mods etc
Posted
thanks
Nice one remember the pictures we all like pictures here. Any before and afters are always good :D
Posted
with reference to changing steering wheel ok with disconnecting Battery, airbag and wheel all with extreme care but what about the slip ring i think its called
Register a new account
Sign in
