1998 subaru impreza sport 2.0 litre non turbo
fitted new apexi air filter today
started up car now i have no tick over
took the apexi off and refitted original airbox but still have no tick over
car starts but just fades out unless i rev it but on a test run it was misfiring badly
any ideas as to why dismantling the original airbox and taking off the maf sensor and replacing filter with brand new apexi this problem as arisen
even with original airbox problem the same
prior to this just done a fault less 250 mile journey no problem
any help appreciated as car unusuable
I would say its the MAF sensor as it is the only other thing you have touched? try disconnecting it when idling
no fault codes
wondering if its worth getting some maf cleaner
ran to somerset from sussex and back no problems this morning about 250 miles
took off old air filter box when i got back cos new apexi had arrived
disconnected maf took it off
refitted maf with apexi cone on
started it up no idle just cutting out
Check the condition of the connections on the maf and it's plug, might have some crud causing the issue.
Also try doing an ECU reset.
turned out to be a loose connection impreza running again after ecu reset
tick over a little higher but that might settle
Battery as gone so just charging it to get out to get another
thanks for great insight / info received
give it a run round block after ecu reset and tick over back to normal
new Battery fitted
have to say the new Battery dont fire it up rapidly but maybe its a < boxer thing >
left it few hours spins over nice and quick
starting ok tick over good seems to run a bit better after ecu reset
thats great to hear - so is the Apexi filter on or off now I lost track :D
apexi is back on
originally put it back to stock to retrace my steps but having slept on it, took the advice and some scooby related reading now back on track
way hey - mind you, you know what they say without pictures it hasnt happened ;)
Apexi Update
After trials and tribulations with fitting etc took scooby for a run and the apexi never lived up to its promise
low down acceleration not so good plus exhaust appeared louder and booming and no get up and go
came home dug out original airbox which as a performance panel filter in it polished out the inside and refitted it.
Did an ecu reset
out for another test run and improved acceleration, tick over and exhaust note appeared better not so booming just a little cackle on over run
been a learning curve which i am glad to have been involved in as now i personally am convinced stock air box and performance panel filter my best options
thanks for all the input throughout
job done case closed m lord  !!!!!!!!!!!!!!!
it may well be the case that the Apexi is more suited to more extensive mods but it goes to show the signification investment made in designing the original airbox has proven worthwile
i reckon your right on that
i gave it a comparison test based on running the same route twice with each fitted so maybe stock airbox and performance filter works better for me running standard engine except straight through exhaust already fitted when acquired vehicle
going to do window motor on passenger side and change two front spot lamps prior to mot and hopefully run it learn with it service it enjoy its potential
mods need supporting mods most of the time but what ever works for you my mate i really like panel filters people seem to think its just the same as stock thats not the case i had a k&n tray filter on my old gsi and it loved it better then the pipercross stright feed
went back to a sport panel filter inside stock airbox
on two identical runs, same roads etc the panel filter was more responsive than the apexi
only mods are straight through exhaust unknown make as on car when i got it
burbles and pops on overun so quite good otherwise stock ( at the moment )
sourced the right inlet adaptor for the new apexi laying dormant in its new box
considering giving it a second fitting as before it was bolted direct to maf
maybe this time round with new better quality gaskets it might show some improvement
my theory is i have a fairly free flow exhaust fitted so the whole idea way back was just to improve the breathing without other mods
will reset ecu after fitting
I was always lead to believe that n/a engines needed a certain amount of back pressure to work at their best .
I've even seen a few tdo4 powered scoobs lose torque with a 3" decat and cone .
will be interested in the out come as I haven't tried any back to back tests with induction .As I didn't want to open up my turbo'd scoob when I fitted a cone filter until it was" mapped in" , but I have experienced a lack in back pressure causing a loss in power with a n/a engine
the exhaust on when i bought car as standard headers cat converter a small 12 inch < silencer > then a straight through back box exiting 3.5 inch rear pipe so id assume not completely straight through so with some back pressure
originally fitted apexi and on two identical runs it ran better without it but that was with apexi bolted direct to maf wheras i can now use a short 76 mm id silicon hose connection between maf and filter
this leads me to wonder if it would make any difference
if not apexi will be sold and idea shelved
