Estate or fastback?
You can guess I have just got my Subaru.  It is a legacy 3.0 R spec B estate - 18  inch wheels 2006 model.  On the door pillar it has a sticker saying Outback n.  So do I have an estate or an outback?  What are the differences?
I think they are known as legacy outback's, but I guess they fall under the estate category of cars.
I think the only difference between the legacy estate and the legacy outback estate is the outback version has a slightly raised ride height.
If I'm wrong I'm sure an outback owner will be along this evening to rectify this [emoji6]
thats as I understood it
From memory, the front bumper on an outback is different to a standard legacy, it has larger fog lights. The ride height is also greater than the spec B
This is were it all becomes so confusing as I have a 2006 spec B legacy which also has a pillar sticker denoting 'outback n'  Ill upload some pictures to give a fuller picture.  The front fog lamps are the standard small ones as found on a legacy.
  • 2 months later...
From 04 the Outback was just called the Outback, they dropped the Legacy name after that.
Think they have a different rear bumper too and mine has plastic on the sills as well
Cheers
Alan
What's the year? And has it hot an outback badge anywhere?
Hi, 2006 3.0 Rn spec B .  Has yellow Billstien suspension front and back if that helps?  18" wheels.   Just a Legacy badge on the back tailgate.
