Facelift - pre facelift dash
Hi don't want to be a pain but as my scoob is like a jumble of bits ,the dash is fine till it gets to the trim that goes round gear stick and where stereo is the parts that's in it don't fit am thinking there pre facelift and not fitting my facelift dash,so has anyone got some pictures of a pre and facelift dash and clocks so I can try find right bits driving me bonkers like a jigsaw trying to piece it all up thanks
Thanks that facelift dash my dash looks same as that up in till the trim round stereo then it doesn't fit same as trim with handbrake and gear stick think they are pre face bits it's like a jigsaw
Mines a v3 they come with facelift bonnet / lights and preface bumper/dash ;-)
so the dash/ interior in my pic is preface
the facelift dash has a bulge above the center air vents , top glove box or air bag on the passenger side and it hasn't got that ridge running all the way from drivers side to passengers side near the windscreen like mine
Mines a 1996 facelift the dash looks same as that post-1928-139971512825_thumb.jpg
Just the stereo and handbrake trims don't seem to fit
Confusing I know but most people class a facelift as a full change ( v4 i think had the dash but preface bumper)
V5 full Facelift had the lights , bonnet , different front bumper (smaller indicators) and different dash .
v3's were a half facelift just the lights and bonnet
I'll try to dig out a pic of a facelift dash ;-)
Thanks what do u think mine is vin comes up as a facelift phase2 wrx so must be ver5
Ok will do the dash in my pic must be pre face and that's the original one that came with car
Looked up pic v5 dash is defo not same as what's in mine it's got phase2 engine like vin says but I was thinking because of when it was registered might be why it has early dash
That's strange
my 97 uk turbo is phase 1.5 and so are all the my 98 v4's I've seen /researched
As far as im aware phase 2 is v5 my 99 onwards
are you sure it's a my 96 ?
As there's sometimes a over lap in the versions pending on what time of year their registered but, not 2 yrs worth confusing lol
Yeah that's what's confusing me it's a p reg here's the vin post-1928-139971839358_thumb.jpgpost-1928-139971841198_thumb.jpg that's plate it had on before my mate got it
It's a import aswell and sti badge on back think it used to come up as a sti plate doesn't come up now because it's down as scrapped I think ave got to get a new v5 and all that aswell my mate was sure it was a sti it's annoying think the !Removed! just put odd bits together lol
Any body else understand this
Just checked your code on the list on here and it says yours is a v2 ( mabey v3 pending on exactly when it was made) wrx .
which should have the phase 1fuel set up v1 /v2 inlet, snorkel turbo ,preface dash, interior , bonnet and lights as far as im aware.
Versions are the look of the car and spec .
phases are the fuel rail and injector set up
I looked it up on google found it was ver5 it's got phase2 loom and engine don't understand it atall asling as it goes am happy but would like to find what it's supposed to be as dash is half done
There any way vin could be wrong or has it happened before
Been puzzling me a bit lol
what makes you say it's got a phase 2 v5 loom and engine ?
As this is the only thing that doesn't add up unless it's had a loom change or has a later v5 4plug ecu fitted .
I have dug out this info which ties up with your plate , year , model code and engine number are all the same for a 96 wrx with 280 hp .
Launch Date: 9/9/1996 Price: 2,555,000 yen
Applied model code: GC8D48D
ENGINE
Engine Type ....................... 1994cc, water cooled, DOHC 16V, Open Deck
block, Boxer Master 4.
Engine Code ...................... EJ20KDW6HE
Rev Limit ............................ 7000rpm
Turbo ................................. RHF5HB
Injectors ............................ 470cc
Bore/Stroke ....................... 92.0x75.0
Compression Ratio ............ 8.0
Max. Power Output ........... 280ps/6500rpm
Max Torque ....................... 33.5Kgm/4000rpm
0-60
Max Speed ........................ 180 km h (restricted)
SUSPENSION & STEERING
Front Axle ......................... McPherson Strut
Rear Axle .......................... Strut
Steering ............................ Power assisted rack and pinion.
Front Brakes ..................... 15” 2 pot Ventilated Disks
Rotor Size ......................... 294x24
Rear Brakes ...................... 14” 1 pot Ventilated Disks
Rotor Size ......................... 266x18
ABS ................................... 4 Channel ABS
Wheel Size ........................ 16x7JJ
Tyre Size ........................... 205/50R16
DRIVE TRAIN
Type................................... Full time AWD, Viscous Coupling
Transmission Type ............ 5MT
Transmission Code ............ TY752VBCAA
Transmission Ratios........... 1st 3.166
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
Overall Length .................. 4340mm
Overall Width .................... 1690mm
Overall Height ................... 1405mm
Wheelbase ........................ 2520mm
Front Track ........................ 1470mm
Rear Track ......................... 1460mm
Weight .............................. 1250kg
COLOURS*
Feather White #30
Light Silver Metallic #06
Active Red #59
Royal Blue Mica #2D
Black Mica #16
Thanks appreciate u digging that out and I have whole inlet in shed rest if engine is sitting in car now all plugs match up don't understand it and he says it was a running phase2 when he got it lol driving me mad
My97 has a facelift dash do you still want a pic ? It's a foz but identical interior,
Sav where did you pull that info from ? Be interesting finding out info on mine,
Sent from my SM-T210
If u have one fiqured out its a pre face dash in mine now
Yeah if it's the same as mine it's preface fella .
stanton that was only for wrxs I'm afraid
I bookmark random pages I stumble across while researching for my mods .
Not that I believe everything I read on the net , even that wrx info is a bit inaccurate as the really early wrxs and sti's had 380cc injectors as standard and I've never heard of 470cc injectors in a scoob ;-)
Did find a random ecu write up for classics that was interesting today lol
http://www.perth-wrx.com/vb/stock-ecu-discussion/53009-stock-sti-gc8-engine-control-unit-numbers-specs.html
Mines the one in pic I put up savage so looks like pre facepost-1928-140001159269_thumb.jpg this one
No worries garry,
Sav you have far too much time on your hands :-D
Would be nice to find out some and collate some info on other foresters.
Mines confusing the hell out of me at the mo.
I've the ecu info somehwere but other things and pics I've seen of uk cars boggle my head
