WTB: Impreza GC8 Recirculation valve
Atlas
Hi,
I got a Subaru Forester SF5 that is running 18 psi and i need a new recirculation valve, since it got the stock double chambered valve design that bleeds boost..
The valve i need looks like this since i have a new Impreza gc8 S201 TMIC fitted:
Price + shipping can be discussed. I live in Norway and i cant seem to find one in my local area or eBay.. PM me or message me here if you got one laying around.
Thanks!
If you cannot find a oe replacement forge do a v5/v6 recirculation valve which looks the same .
http://www.dcperformance.co.uk/uprated/forge-dump-valves-and-accessories/subaru/impreza.html
Sent from my GT-I9300 using Tapatalk
Really hard to find those valves, so it looks like i have to buy an aftermarket replacement..
Do you know if the Impreza V5 Piston Valve will be able to handle 17-22 psi boost?:
http://www.dcperformance.co.uk/cheap/195119/subaru/forge-dump-valves-and-accessories/fmdvv5013.html
Thanks for your help. :)
Unsure about the v5 oe type but, the oe recirculation valve on my v3 ran fine @ 20 psi .
I'd imagine that the forge piston type would handle more boost than a oe diaphragm type .
Mabye drop them a email to confirm what psi their rated to ;-)
I did, but they didn't confirm how much PSI it handles. I guess it will handle it if they didnt write anything.
By the way, someone locally here got a 2003 impreza blobeye recirc. Will it fit my TMIC?
Have you tried cross referencing the valve and gasket part numbers .
I personally don't know enough about the later recirc valves to know if there the same
Good idea.
They have a different part number and they look different in width.
GC8 = 21896AA050
tn_21896AA050-subaru-dump-valve-gasket-R
GD8 = 21896AA072
tn_21896AA072-subaru-intercooler-gasket.
Might be able to fit it IF they got the same bolt pattern, but i couldn't find any descriptions of that.
EDIT: I got this answer from Luke @ Importcarparts.co.uk:
"You cannot put a GDB Recirc valve on a classis as the hole in the intercooler doesn’t line up with the hole on the valve and it ends up sucking air in from atmosphere"
I have just ordered a Forge Motorsport V5 Recirc Valve. Mods can close this thread now.
Dan @ Dcperformance said this regarding max PSI:
"Out the box they go up to 26 psi, and you can  go to the red spring which is around 35 psi"
Thanks for the help everyone. :)
