Cree LED sidelights
majik_thighs
Ive had them on my cars for the past 5 years and been stopped for various things and not one rozzer has mentioned them. they`re not so bright as they blind anyone.....lets face it  the stock ones are **** poor.
Its supposed to be illegal to have blue lights showing on any car except emergency services.  :rolleyes:
lol @ rozzer
thanks mate.....just was on a bulb-selling site and the description on some (stupidly expensive) phillips T10's said they were ok for internal, but not external use.
Can't wait for mine to come now  :D
Shows the location of the bulb, if you take the Battery off it will be a breeze. Do this one first.
post-2579-0-34152300-1409838359_thumb.jp
Same on the other side, not as easy to remove the airbox but it will make the job easier if you do.
post-2579-0-29845800-1409838379_thumb.jp
At first it looks like the LEDs are too big to fit in the same hole as the stock bulb but if you line it up you`ll find they will just fit.
Had a look tonight as it was getting dark to see if I could locate the sidelight bulb holders....think I've found them and depending on how they come out, may not need to remove Battery or air box.
So - first question - are the holders a kind of figure 8 shape with 2 sets of wires coming out the back?
Second question - do I twist to remove holder from socket or just pull straight out?
Tried to locate video online unsuccessfully [emoji20]
Had a look tonight as it was getting dark to see if I could locate the sidelight bulb holders....think I've found them and depending on how they come out, may not need to remove battery or air box.
Yes, I think its the figure eight thingy. and yes, just a short twist and they come out. The LED is just a fit and just pushes back into its wee hole without needing to twist it.
If you can do it without removing said items then your a better man than I
Have fun :)
Led's in, literally a 5 minute job. Nice n easy once I knew where the bulb holders were. Thanks mate; such a cheap job, such a good result. Sides on at all times now I'm thinking [emoji106]
Wahey!...............Always nice when a plan comes together........you see what I meant by a tight fit?
Good thing about these, they last forever. :) and how bright are they huh?
Yeah mate, tight into the holder but fitted back through the aperture fairly easily. I'll try and get a pic when the light starts to go. They do look great though [emoji41]
I was going to ask actually; have you ever had to replace a bulb?
I swapped them over from the last OB, I was going to get a couple of spares, at the time they were only available from Australia but now they`re closer to home, no need. LEDs outlast normal bulbs and draw less power.
