Wheel stud advice
So it turns out I need a new stud in my hub as it is chewed to hell!
Only trouble is I have no idea on where to start, help! !
It's a non turbo bug wagon if that makes a difference
Thank you
I dont know what setup you have - disc drum etc however the stud itself will be removed from the back of whatever mounting plate is part of your hub. If it is really tight dont wail on it with a lump hammer as you could damage the wheel bearings but many of them just require a gentle tap, generally the front will be easier than the rear.
the stud itself can be sourced from a dealer or here is an example on ebay - check with the supplier that it will fit your motor
http://www.ebay.co.uk/itm/Subaru-Impreza-2-0-STi-01-to-04-Hub-Wheel-Stud-Bolt-Genuine-Subaru-28055AA003-/280963108347?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ASubaru&hash=item416ab4cdfb
fitting the new on is a case of coat in wd40 or oil push through the hole and tighten up using a wheel nut and some washers as spacers, this will get it in place
