coilover pro's & cons
Would I be looking at complete impreza coil overs then that will bolt straight on
  • Replies 91
  • Views 12.4k
  • yes, the moment you start changing suspension parts you will need to do alignment. it's always a good thing to check that every year anyway IMHO
  • Hi mr B. Right before you shoot me to bits I ended up with a mix, thepedders lowering kit, firstly because the said they also had 2 year gaurantee on the shocks and springs, & I couldn't get the
  • Not entirely sure, never looked into newage stuff but they changed the tops on one of the later models so you may need to swap to older top mounts with new age shocks. Those coils should work with
2nd gen saloon coilovers should fit, worth email BC & see if actually list for Forester SF.
Best solution is 2nd gen Impreza wrx saloon original struts (even top hats off these fit fine & not as old which plus point when buying used)
Impreza shocks are shorter in terms of rod stroke compressed & extended & drop a forester quite a bit.
Main issue with this route is you will need test fit & measure on standard springs then get custom springs made to get rear sitting higher as saloon & even wagon rear springs are too soft/short on forester.
Custom rear springs would be about £120 a pair so if you find decent set of original shocks complete from someone who swapped to coilovers you may get it done for under £400.
You will need quality alignment once done & don't go stupidly low as geometry/handling will be ruined.
Www.subaruforesterparts.co.uk have them listed with 6kgm front and 5kgm rear. Bc will do them to what ever rate youd like but will cost more as everyone else is offering discounts.
Www.scoobyparts.co.uk has a full range of spring rates to order so if you can find somone with a set willing to give you a test ride you could order yiur desired setup for discount
Any good discounts on BC through SOC & a retailer ?
I would go 5kg/mm front & 4kg/mm rear at most, BC not cheapest but if shop about should get at £660 to £680 easy enough & if have retailer on here hopefully even better than that.
The plus with BC is they will supply custom rate springs at no extra charge, also they quite helpful with spare parts & servicing unlike lower cost options.
Cheapest & best road use option but not simplest due to needing faff around sorting custom springs is impreza strut swap.
Simplest in terms of bolt on & adjustment to requirement is coilovers but without sensible springs & setup it would be a back breaking buckaru :-S
I could do with seeing stantons set up first before I make my mind up lol
I'll have a comparison picture up tomorrow morning for you mate soon as I'm at work
Your dragging this picture out lol
Haha sorry mate I took on on friday before I left of the old set up, but not had chance to go in and take an after shot, took one at home last night but it's not on level ground so can't really tell the difference,
Before, the back doesn't look to bad as there are a set of grayston spring spacers shoved underneath
After doesn't look much different but it is, check round the sides of front arch to see
Sitting level :-D
If you stuck a set of 17" under there you'd get the desired look
Can see it lower on front after & sitting level.
Would assume pedders base their lowered forester kit on shorter stroke impreza shocks.
Will be keeping my eye open for a tidy 99/2000 SF Turbo in red or green :-)
Ooops, posted in wrong thread :-S
Sitting level :-D
It does look nice.What size wheels have you got on?
Standard 16" with 60 profile tyres, It's coming down lower now the springs are bedding in :-D
Drove to hull yesterday with baby and associated items, managed 34mpg which is th best I've ever had so shows that I was loosing drive due to crap springs
What turbo do you have strapped to your forester?
Td04, mate
As for those coil overs I reckon they should fit as all top hats were the same for the early cars impreza and foz share the same part nos
As she is after a week of driving
Ive just put a cheeky offer on ebay for the coil overs lol.Your doing well if your getting 34mpg lol is it mapped yet
Nope :-( thats where my suspension came from instead
suspension? ive lost you now lol
Haha the new suspension parts came out of the remap fund :-(
I get you lol.Who are you going to use for the remap
Hopefully simon at jolly green, he's up in Sheffield next month and I'm working on a plan to release some funds, trouble with mine is it needs an esl board grafting onto the ecu as the 97-98 cars can't be remapped by flashing the ecu .grrrr
