Help
  • Replies 58
  • Views 6.2k
    I've got a sub frame, links ect but I'm in Suffolk . It's quite rusty and still on the shell but if you can be arsed to come to me and remove it you can have the whole thing for a score [emoji6]
  • Check for the real damage before buying anything. I know they say 99% but there's still 1% it may be something else. Wouldn't want you wasting money.
  • Id hate to see another classic go to a grave [emoji26]
Isn't much better then mine really is it. But maybe with a sand down n some paint mite get away with it on a MOT
I have seen this on eBay do you think they would fit on to a classic like ours? I think there for the newer impreza's like.
That looks like the underside of a classic but with different links n arms like in the pic above
And the ones on eBay are adjustable anyone with advice about this can it be done?
Did you say the sub frame was buckled too? I can imagine those arms/links will work if you're doing both sides as they're adjustable but I don't know much about the in and outs of it all. Not sure if I would trust an adjustable joint on my daily car. And the set up will take some intricate measuring.
Yes subframe is way past the point of been fixed will need replacement. The Wright up for them sound good but there not for comfort. But if you wanted comfort you wouldn't buy a impreza haha
Yeah that's right. I know the rear track on a classic is 1450mm have a look about for the size of new age cars if they tally up then I don't see much reason they won't fit. Check the wheel base too. I don't know that measurement. [emoji14]
This is from a car in Sheffield that's being broken if your interested
It's at Sheffield subaru service give Martin a ring 0114 2430099 it's not advertised as being broken yet so if you call say your on here and adam & ash have put you onto it
No worries, you may have to call back as they are always really busy so he'll have probably forgotten
As stanton has said :)they will have forgotten mate, i know he had to do a test drive for a customer earlier.
I guess he's waiting for the guy who's car ut is to give him a price,
