BOV HELP!!
Hi the nipple on the top of my BOV has snapped! I wont be able to get a replacement till monday however i think iv got a audi tt diverter valve, will this work if i just vent it to atmosphere?
in theory yes that will work - you may have issues though if the spring tensions are different meaning the valve will activate at different pressures, why not run without the BOV fitted until you get a replacement?
If you Blank the vac pipe to the dv , remove the dump valve and bung the hole it comes out of .
You'll get flutter (turbo stall) and the gear changes might be a bit lumpy but it shouldn't harm anything if it's only for a short while
The flutter sounds ace too. But like savage said be ok for a short time.
Ok so ran it for a day and it sounded weird so got a dv first thing today. Bought a genuine hks ssqv with fitting kit. I have to say it sounds so weird!!!! On low boost it does have a bit of a psssst to it but on high boost it chirps sounds like iv got a bird under the bonnet!!!
there is a bolt on the hks that can be used to adjust the spring inside, this will give a more predominant psssst or slight flutter, mine does both though and i prefer it like that :)
probably take some getting used to! However my boost topped out at about 10psi! So my old BOV look like it may of had a minor leak!
is it remapped ?
Hasn't fix idle issues but iv been thinking (not normally a good thing) the ecu i bought has MAF delete when i use that ecu the idle runs solid at 1500rpm (rotational idle with als) does this point to MAF? When I unplug it one original ecu car stalls
Its not remapped, does have a chip but guy I bought it off said it was running 260
that would mean its remapped, id get your car looked at on a dyno to be safe as you could be running rich, 0.7 is 10 pis which is standard boost, if so im afraid your running about 212-220 at best
I was told 1994 wrx is 260bhp?
Is that the standard chip in a z4 ecu?
post-3785-0-66020600-1424731439_thumb.jp
apologies i thought it was a Turbo 2k
J D M - "Import" Model Codes Type/Version/HP
•    1992 - 1995
GC8A48D.....WRX 4 door / 238
GC8A47D ... WRX Type RA 4 door / 238
GC8B48D ... WRX 4 door / 248
GF8B25D =. WRX 5 door / 218
GC8B47D ....WRX Type RA 4 door / 258
GC8B47D =. WRX Type RA STi V1 4 door / 272
GF8B58D = .WRX 5 door / 218
GF8B58D =. WRX Type RA 5 door / 248
GF8B58D =. WRX STi V1 5 door / 258
GC8C48D = WRX 4 door / 238
•    1995 - 1997
GC8C47D =.WRX STi V1 4 door / 258
GC8C47D = WRX Type RA STi V1 4 door /272
GF8C58D =. WRX 5 door / 218
GC8C4ED =.WRX STi V2 555 4 door /272
GC8C4DD =.WRX Type RA STi V2 / 272
GC8C4DD =.WRX Type RA STi V2 V-Limited / 272
GF8C58D = .WRX STi V2 5 door / 258
GF8C58D = .WRX STi V2 555 5 door / 258
GF8C58P = .WRX 5 door AT / 220
GC8D2DD =.WRX Type R STi 2 door / 278
GC8D48D =,WRX 4 door / 258
GC8D47D . .WRX Type RA 4 door /278
GC8C48D thats my engine code so it will of been chipped to 260?
it seems very strange that it would only make less that 30 hp if im honest, hence why im saying take it to a rolling road, for it to get an increase in hp there has to be and increase in boost, however yours is running totally standard boost pressure, if remapped, most scoobs run around 1bar of boost or around 12-14 psi depending on the turbo, fueling etc.
http://www.worldwidemetric.com/measurements.html
Well I have it at the mechanics tomorrow so I will get him to check for boost leaks. Will have to get it on a rolling road.
Hey guys, my mechanic has found a split pipe, its a small U shape that runs close to the throttle body anyone any idea what its for? Appears to be a very stiff pipe looking for a replacement.
Doesn't appear in either, mechanic is going to put a silicone hose on for time being will get a photo tomorrow mate.
