2008 JDM wing mirrors (smaller than UKs)
just picked these JDM mirrors up...
still un decided as to fit them or not.
what do you lot think?
Got a photo of them installed on a car?
I make Films and Website for people
Look loads better, if they fold and everything so work the same I would say go for it.
There's an eu directive that states the mirrors must be a certain size that corresponds with the car.
Something daft like, times the length and width of the body, divide by x and you'll come to the square area needed for the mirror.
Have you seen them in the rolls Royce phantom ?
I'd stuck them on if you don't like you can always shift them on
just posted this on SN too..
started to clean them up tonight, also touched up a couple of stone chips.
this is me offering it up and the same level as the ones on the car.
quite a bit smaller and more rounded design.
I'm a bit worried about fitting the, door panel off etc :(
I resprayed the triangle bit that fits to the a pillar on mine.
You just need to take the door card off, remove the tweeter and that gives you access to the 3 bolts that hold the mirror to the a pillar. The only issue I had was that the multi plug didn't fit through the hole in the a pillar so I had to cut the wires. Refitting meant resoldering the wires back on to the multi plug.
