EML not lighting up?
Wow. Super tech answer!! Not sure about disconnecting battery as not sure of how to reset alarm and add code & radio code Anything else is beyond me. Though garage might have sussed it, bit I would have to give them longer to find the needle in the haystack £££...
  • Replies 51
  • Views 7.9k
  • If yours is newer than 99 you can use odb2 to read codes, some scanners also support ssm but it's not essential. If you got the cable and pc ssm software you could do a lot more with it but for inve
  • Have you grounded the CEL wire to ECU & found CEL light works ? You also want test what the CEL input terminal is doing at ign on (should be switched earth while light on then if no faults open c
  • Probably bulb so best dash cluster is pulled so can be checked. Not unusual for a bulb or 2 to be blown.
Alarm no hassle just don't leave your keys in car with doors shut as in some instance alarm will arm or activate central locking then you locked out :-) keys best in hand then is sirin starts squeeling you can blip it off.
not sure on your radio code so check that with the radio manual.
