Hi all I'm new here I thought I would post a pic of my rebuild.
My engine suffered a head gasket failure so I thought I would do the whole lot. It's a good job I stripped the engine the crankshaft was showing excessive wear on the main and big end journals. The bearings themselves had started shedding although it wasn't knocking it was ready to give up. Probably oil pressure failure.
post-4327-0-24390100-1430575848_thumb.jp
Hi mate welcome along. Have you just started the rebuild [emoji20] bit least being doing it all so should be all good after [emoji106]
Yes mate started it last week, took the heads up to roe engineering in fleet this morning to be skimmed the Crankshaft will be replaced its badly scored also oil pump and the modine, they are magnets for metal swarf.
should be a gooden when it's done :-)
Oh nice. Be interested to see this progress. I'm on my phone at the minute but I'll move this to the project thread if its not already and pin it for you in there [emoji106]
Well guys still going through the intense strip down period. Just thought I would upload a few more photos of work in progress so to speak. Although the parts have been cleaned just prior to re assembly everything will get sprayed with thinners etc to make sure it's all ultra clean.
post-4327-0-67473200-1430744358_thumb.jp
post-4327-0-08673100-1430744412_thumb.jp
post-4327-0-02680800-1430744463_thumb.jp
post-4327-0-67442800-1430744508_thumb.jp
Also thought I would post the state of some of the shells... notice the tri metal coating has been stripped away. Knackered oil pump was the problem here.
post-4327-0-79939000-1430744747_thumb.jp
post-4327-0-22064700-1430744789_thumb.jp
This is a friendly pointer to anyone new to this who is attempting to rebuild their scooby. You might be tempted to save a few quid and reinstall the modine oil cooler. My advice to anyone is bin it! Although this little puppy looks clean and however much you try to clean this, bearing fragments will undoubtedly be caught in all the little nooks and crannys. If I were to install this back on my new build I'm pretty certain that all those new bearings would get a coating of previous bearing fragments.
That's just my friendly advice
adam
post-4327-0-83307600-1430745526_thumb.jp
Nice work so far fella [emoji106]
Good point with the modine, I just had mine chucked into the engineers hot wash a few times but it was running fine when I pulled it apart [emoji15] [emoji5]
Are you giving it a refresh or fitting some upgrades on re assembly ?
Best of luck adam and keep us posted bud [emoji106]
No exotic upgrades for this one. It's gonna have a new crankshaft new rods new modine and high volume oil pump. I have a couple more ej20 lumps in my workshop I might do something with one of the others using forged parts in the future etc... but for the moment I'm just keeping this one standard ;-). The misses already complains because I'm spending too much time in my man cave lol.
  • 2 months later...
Hi guys
I'm sorry it's been ages since I last posted about my rebuild.
I have been out of the country etc.
Well I'm back now and back on it with a vengeance.
Just received a few bits this morning so I'm starting to put it back together shortly after this post.
Regards
Adam
post-4327-0-34660400-1436608358_thumb.jp
Hi all
A little more progress since yesterday. Honed the cylinders out, installed new crankshaft, new con rods piston rings etc
So at least the short block is nearly finished.
post-4327-0-65392700-1436716616_thumb.jp
post-4327-0-43298200-1436716644_thumb.jp
post-4327-0-00991200-1436716688_thumb.jp
Looks good I'll be doing this soon :-)
No Tidgy, this one's going back in the car as standard etc, but I have got two other blocks in my workshop that I might
do something a bit special with.
