Best suspension upgrade?
Hello all, in terms of suspension my 03 blob impreza is all stock. I don't want to spend too much so what would you recommend to make the best handling without making it too hard to drive?
Lowering springs + Rear sway bar
Or do I need to save up and shell out on coil overs?
Sent from my D6603 using Tapatalk
waste of time getting lowering springs as you will most likely end up forking out for new shocks later on,
I fitted racing logic coilovers with track springs/fast road use, and alloy drop links front and back, ive then took it to carnetix to have it professionally aligned and setup for fast road. the car is alot more chuckable, but slight bumpier on straights due to the nature of the springs.
Thanks ash,
In terms of getting a new rear sway bar, what bits do I also need to support the upgrade? in terms of links bushings etc
24 mm is the strongest one but on yours i cant remember how easy it is too fit ?
Which ones am I looking at the c shapped ones or the link things? I'm not too Keyed up on what goes where and what does what, job for garage :,)
22mm would be good for road use if your not going to change the front bar, if you can get the adjustable ones the front hole normally equates to 21mm and the one furthest away is 23mm so you adjust it to your tatses not sure
about the links on the blob but if you can get the c shaped ones there are obviously stronger so I'd get them.
Arb's can be the easiest things to fit but they can also be a real pain.
Thanks stants, I think that's what I will go for :)
Any lowering springs that wont ruin ride quality? Just wanna loose a bit of wheel arch gap?
Yes, road use, but want it to handle well on the road
What's difference between anti lift kit and anti roll bars, I know what the bars are but not anti lift kit
totaly different components.
Anti roll bars stop the body rolling left to right, anti lift kit stops it pitching when you accelerate and decelerate.
arb
anti lift kit, its the gold bit at the end of the lower arm hes holding
Ahh I see :) thank you!
:) I think these may be good to add to my list as the front rises alot when hard accelerating
credit to ya tidgy, you realy know ya stuff.
decent shock and lower spring is a good compromise!
Coilovers can be very harsh
Thanks guys, so I'm thinking shocks, lowering springs, rear anti roll bar and anti lift kit?
i had a anti lift kit for mine, never fitted it ! might be handy for santa pod tho
