Oil pressure gauge install help please!
  • Replies 53
  • Views 5k
  • Managed to get to the sender, hooked all up fine, although a 24mm deep socket would make life a damn sight easier! Had a really annoying leak on one of the cone fittings, managed to get it to seal aft
  • Mines going in this afternoon I hope
  • You'll need an adaptor as the hole under no 3 is blanked off, i'm in the process of moving my pressure from n03 to the alternator, and sticking temp in 3. DO NOT BUY THE GALLEY PLUG FROM SUBARU it'
Tried the screwdriver wrapped in a tea towel method, but couldn't actually get into the bit I needed to. Will try needle nose see it it works any better!
The rear of the cone fitting that goes into the adaptor into the block. That means stripping out the alt etc again which in itself isn't hard but just time consuming. And I know if I do that I'll end up taking all the t piece line apart and starting from scratch. If it's already there and oil tight I don't want to mess more than I have to!
