newbie needing help
hey all new here, owned a subura impreza for nr a yr now, not a wrx sti  she is just a sport.
can anyone help  with fitting my rear wheel bearings the garge want nr 200 and I have got that sortta money, is the anyone in the Littlehampton area that can fit them at a reduced cost :)
hey :)  that would be cool, do you have the tool to remove the bearing ?/
I'm in the same boat right now. If the bearing has been bad for a while it may have scored the hub too. I'm buying the whole hub with bearing for £50 and fitting it myself as its all nuts and bolts. I'm replacing the hub and sending mine away to pressed and check before fitting a new bearing in it. But this way the car is still on the road and not making a racket.
If the garage remove the old bearing and find the hub fubard you will be up **** creek trying to decide what to do about a new hub.
cheers hun :) this is turning into a nightmare. but all taken on board
good jap bearings are 30 to 40 £ each set, hub bearing puller tool can be had for snip under £44 & good enough for diy enthusiasm & light trade use. these kits make it real easy & less chance of damaging a bearing during fitting. Hubs & spindle normally ok unless bearing got silly hot or seized & spun.
main trick is don't use cheap or non jap bearings & get it fitted by someone who knows what they doing or wheel bearing failure start becoming a monthly problem ...
ok cheers  all advice taken on board, picking up bearings today  costing 45 so gotta be ok
sounds promising :) I have the bearings now I picked them up today
Wotcha and welcome - keep a camera handy and if you get stuck just post some photos up and it makes it easier to point you in right direction
thank you
