Subaru remapping
Hi all
I would like to remap my scooby can anyone recommend me a place where they dont try and rip
you off as i have had radiculous quotes.
Car is a subaru impreza turbo 2000, 1999 version 5.
Hi mate what have you been quoted ? Anywhere between 400-1000 is normal depending on what ecu you have and what's compatable with your year, and all depends on what kind of features your after as well
Some ecu's can run open source software which brings the cost down considerably some need a daughter board grafting on or you could splash out in an all siinging all dancing standalone like syvecs
Try giving these a shot
http://tdracing.co.uk/
Yeah 400-1200 quid roughly depending on what system
£490-£1000 is roughly the prices I have been quoted. I didn't realise it would cost this much for such an old car and all I want is a remap sounds like a lot of money.
Pretty much usual sum for a remap no matter what car
It's not like other stuff like flashing vw's which is a simple affair, your looking at, ecu/ software, mapper &dyno time but it will be properly set up
Yeah that's technically slave file pushing its not a remap just a generic Rom map uploaded onto your existing set up someone has made in a factory setting
My last full on remap was
385 map
70 fuel ( road map and fuel getting there )
75 new maf as mine was shot
40 solenoid
Needed some vac pipes too
Result = smiles
Matt where did you go for your remap? and how much bhp are you pushing?
Just to add im installing a vf28 Turbo before mapping.
I ran a vf28 and hit 318ish but I didn't go silly as my clutch isn't that great
But now I blew the turbo up ! Got a vf35
I am running eculabs mate which is pretty new so cheaper
Basically your options are
Budget:
Apexi
Eculabs
Ecutek
Higher :
Simtec
Alkatec
Syvecs
Alkatec is good, Syvecs is better lol
Im going maffless too
O don't get me wrong, syvecs is the way to go if you have the extra cash, i would always go syvecs myself which is why i have one, but for a simple decat and map its prob a tad ott at £2k unless you have the spare money lol
Alcatek will do the job fine
Alkatec is still too expensive I think if he is worried about the 400-1k quotes
Isn't it about 900 quid for that ?
tends to work out a bit more than an ecutek, but the added benefits it brings are worth the extra imo. Can take a couple of visits to the mapper to sort out cold start (uinless you leave it with em for a couple of days) but once thats sorted then all good.
Btw ecutek is about 550 to install and set up roughly
( have to buy a license )
just to add it varies from car year to car year, also anti lag and launch control are cost options, not that you need em on a road car anyway
They are fun tho !
Thank you guys for the information I have contacted a few places and asked for prices on installing my turbo and remap.
Are the injectors on a v5 subaru impreza turbo 2000 the same as an sti v5
How did your turbo blow matt?
Did it have high mileage?
Not really about 75k
Smoked a lot ! Luckily I got it off before some of the insides went into the engine area
Injectors are the same cc yes
You an upgrade to a 550 but not worth it , my mate had 750s in his sti6 but we're only on 60% duty
doubtfull you'll max the injectors on a vf28 so i wouldn't worry about it.
my 28 needs replacing before its mapped, seals are going and now and again it kicks out odd blue smoke.
i bough my vf28 turbo its second hand out of a 45000miles sti version 5.
I am planning on installing it and then when i found a remapping place go there and get it mapped.
Ive been told i can get 310-330bhp safely.
