Posted
Hi guys ,I'm new on here bought a 2005 wrx last  year and decided to upgrade today
Td05 18g hybrid turbo
Hawkeye 560cc injectors
Silicone inlet manifold
Walbro fuel pump
Decat down pipe
It's all in car runs fine no leaks etc does not boost properly and I haven't pushed it tried once shall o go straight for map need a bit of guidance please
Posted
You Gotta go for the map otherwise you'll have problems. You can't just add bigger turbos etc without a remap. Who fitted it all. If it was a garage they should have told you that
Posted
If you've done all that work in one lump that's a hell of an upgrade, I'd say you'll definately need a map
Posted
The change in bigger injectors will mean it's probably over fuelling and the boost map will be miles out due to the bigger compressor and lack of cat .
I wouldn't drive it ,especially not on boost before you get it mapped .
Posted
Like above, will definitely need a remap so find someone reputable close to you as driving without one is a no-no.
Sent from my GT-N7105 using Tapatalk
Posted
Hi guys yes I did it in one go over the weekend I have a lot of cuts and bruises!!!its booked in for a custom map on Thursday been told to drive it at 2000 rpm all the way no pressing the pedal.
Thanks for your reply makes sense now I was just worried checked it all again today let it hit temp ,it's fine so off we go it was running 225 bhp standard so should be alot quicker now.
Register a new account
Sign in
