Classic sports cat , elbaich springs ,rear shocks ect
Classic sports cat downpipe, believed to be 100cpi with divorced waste gate (flowed well enough to make 330hp on my uk turbo ) £150 .
4x Classic elbaich pro springs ,which are progressive rate (stiff in the twisties and softer on the pot holes) lower a uk or wrx 30mm £100 .
Pair of Classic Nearly new rear shocks (done 2k mls max) £70
Pair of classic Nearly new Group n rear top mounts (done 2k mls max) £90 (£120 new).
Momcom phase 1.5 (v3/v4 )parallel fuel rails £50
Classic 3 port boost solinoid £30
Whiteline pigtail front droplinks for classic impreza with steel arms £15
Tdo5 16g front entry coldside which i used to convert a early top entry turbo
£40 .
Prices are based on collection from ipswich (Suffolk) pics on request and I'll probably add more as I find it [emoji6]
Hi savage,
Just wondering if your sports cat is still for sale and is it just the cat or is it attached to any pipe?
If so would you be able to post a picture?
Ive sourced a cat back system, and need to find a cat and the pipe going to the turbo.
Cheers
Yeah it's a standard length downpipe that has the standard 2.5 " conical fire ring gasket fitment and separate off take for the internal wastegate .
I'll dig out a pic a bit later, bud
The cat back end is flat flanged and it's got 2 temp bungs . 1 at the top near the turbo outlet for the v3 onwards o2 sensor and 1 at the bottom for a egt sensor (if you've got 1)
Cheers bud, ill pm ya now
Here's a few pics of the haywood and Scott slip jointed up pipe for sandy
2b6ed4dbee9b34848d1b17499e20eb6f.jpgccf52c27cff4a247f8ada0fbc5e5753f.jpg8aaf229076e15394557be5d8df9b3b17.jpg8da425e913824e526810b5e9f9885c34.jpg
There's a little bit of surface rust .
it's got a bolt with the end cut off bunging the newage up pipe sensor hole (not needed on classics and it did the job ).
And as I said before it ideally needs re heat wrapping.
But the studs are in good nick and it worked fine on my classic [emoji6]
Let me know if you still want it and I'll pm you my pay pal address and pop it in the post tomorrow, chap .
Cheers Clive
5 minutes ago, savage bulldogs said:
I'll pop it in the post tomorrow and forward you the tracking number ,bud .
Cheers pal! :afro:
Just posted it ,pm'd you the tracking info and it should be with you by 1 tomorrow.
It only cost £1 extra to send than I thought, so just by me a can of coke if we meet at a show sometime [emoji106]
It only cost £1 extra to send than I thought, so just by me a can of coke if we meet at a show sometime emoji106.png
Legend mate, thanks!
Arrived safe and sound... Cheers!
Nice 1 ,Guess you'll be busy at the weekend then [emoji1]
Forgot to mention don't panic if it sounds like it's blowing for the first few seconds when you start it up .....
That's because it's slip jointed once the gasses warm it up it will expand and seal [emoji6]
That's because it's slip jointed once the gasses warm it up it will expand and seal emoji6.png
That's spooky... I was about to PM you to ask that very question. I've heard that was the case but wanted to confirm.
Pretty much straight after I finish work at 7AM on Saturday I'll be tearing the car down, already roped in a mate to help! (don't worry, will be using my wifes car for work so my car is stone cold) :D
  • 1 year later...
Seeing as i haven't advertised this lot anywhere else , I've still got most of it .
So thought id bump this buried thread ,to see if any of it is any use to anyone on here
alright mate Do the shocks come with springs or is it just the strut?
Just the rear strutts ,bud .
the elbaich pro springs and group n top mounts are listed separately .
Here's pic when i removed them , only things not there now is the front strutts and top mounts . (they were fubar'd) c208b8178c6b67b90b3b298c83bfb8ef.jpg8fc7f30343aa36105883344f19353e93.jpg
  • 2 months later...
Hi is the sports cat still available?
Pm'd you
