P0026 error code
I've changed the oil and cleared the code only to have it come back. What should I replace next?
Sent from my LGAS992 using Tapatalk
P0026 SUBARU - Intake Valve Control Solenoid Circuit Range/Performance Bank 1
Possible causes
- Dirty engine oil
- Low engine oil level
- Faulty intake valve control solenoid
- Intake valve control solenoid harness is open or shorted
- Intake valve control solenoid circuit poor electrical connection
If you changed the oil have a look at the remaining bits [emoji5]
Could the oil pressure switches be causing the code? Intake valve control solenoid was replace just before I bought the car.
Which side is bank one?
Replaced the one on the passenger side. Changed oil. Inspected wires for damage. All ok. Still have a pool code coming back after clearing codes. What do I do next?
Still have a p0026 code.
Have you replaced the drivers side sensor (bank 1).
How long between oil changes previously do you know?
Ordered for the drivers side I don't know about previous oil changes. But I've given it 2 in 1500mi to try to get this code to go away.
44 minutes ago, savage bulldogs said:
Cylinder 1 and 3 are on the drivers side , (right bank) but I'm unsure what side is ment by "bank 1 " .
It's an American thing I think 😒
Yeah, I wasn't being picky I've just never heard the terminology before .
Also The classics have got "LH" on the underside of the left head and I suppose you can guess where "RH" is [emoji39]
