What if front cv joint goes
As above coz my osf cv joint is clicking but if it goes completely will it still drive the rear wheels or will the car go nowhere, I know I should get a new one but the damage is done now and there's no fixing that one so I'm just hoping it will last till I find a new one
If it's just clickin and not knocking It'll take forever'ish to fail if still greased and driven sensibly, but just buy a new one and fit it they are as cheap as chips
I also have no idea if it will still drive if it fails completely other than the chance that you'll probably have a driveshaft flailing around under your car smashing everything to bits
I had a front cv fall apart on my uk turbo . It will move but I had to nurse it at 2k for the 3 miles home . It made a hell'va noise and I was lucky it didn't fubar anything else tbh .
It will probably wind your central diff up and you'd be better off fitting a new one asap imo .
Cheers guys I will put a wanted post up in a bit thanks
