Possible blown turbo
Hello can anybody help me I was driving along today went to accelerate and the turbo sounded different like a hissing noise and won't boost also it tries to cut out when coming to a stop with clutch in not smoking yet but drives like rubbish any ideas how to find out without spending money no lights on dash nothing
Had a quick look can't see any pipes split or cracked anywhere
It could do if you lose enough vac pressure. Must be a mighty leak. Have the car running and listen from under the bonnet. Try to give it a little rev to increase pressure making a leak more obvious.
You have a lot of pipes to check takes a good hour to check them all and he inlet cracks when under pressuec
