Sun visor poor design?
Seems like the sun visor on the 2008/9 MY hatchback is not a strong design.
The up/down mechanism (a plastic cam) has failed on mine after only 45k miles. Just posting so we can see if this is a common fault.
A main dealer new one is around £60.
I suppose it is down to the number of east or west journeys you do when the sun is low
Hmm i wonder if thats why mine has black sun visors in and roof lining is grey.maybe. one broke and they could only find a second hand pair in black.was done before i got it so can not say for sure but i allways said they wasnt right ones in car.anyone else have black ones with a grey roof [emoji53]
yup my 08 RX has issues holding the position I place it in - £60 seems excessive for a piece of plastic - I was debating wrapping some tape around the bar to increase friction. Do you have to buy the whole sun visor flap just to get the retainer cam?
A rarely use them lol an if I do they are all the way against the windscreen
It comes as a complete assembly (as per photo), the part number is for Trim Code: G30,  Colour Code: C6P
Once the plastic cam round the steel shaft has broken, it's history.  In my case it came apart leaving half of it inside - the only way in is to cut the plastic covering which would leave it looking like a taxi. :cool:
If you don't need the mirrors, the only difference between left and right is the spigot that attaches to the body - that broke too when I tried to get it apart.
Im exactly the same i have to be basically blinded before i drop them
Well just 'cos it's there, I decided to take it apart :biggrin:
It's made up of about 10 parts heat sealed in the outer sleeve
