Rev limit
Hi all I'm new here was just wanting to get some advice my rev limiter seems to come in at 5600 this seems a bit low to me is there a way to adjust it my car is a 2006 Hawkeye wrx
Hi,
Your rev limit should be just over 7K.  Its an electronic function set in the ECU.
Does you car have any aftermarket bits?  Are you 100% its a limiter your reaching and not something else.  Is it consistent in every gear and drives normally up to that point?
hi
it's got a panel filter and back box are the only mods I can tell at the minute I've only had it a few months same in every gear car drives good in every other way
Sounds like some kind of limp mode
Get this checked out asap, could be pulling timing due to detonation, very bad on a hawk !!
My 2003 blob did the exact same thing when i put a cheap short ram intake on it
It bounces off like its hit the Rev limit its got plenty off pull upto that point it just catches you out as it gets there so quick it's going for cambelt shortly so will see if they can find anything with thanks for the advice guys if anyone else can think of anything please let me know
Just a thought but if someone had put a manual boost control on and locked it in its lowest position would it cause the same issue I'm having with the Rev limit being so low
