Paul888 Posted April 22, 2017 Posted April 22, 2017 Hi my GC8's rear arches are fairly rusty not the worst i've seen but bad enough,inner arches are good . Any idea on cost to have an arch done with paint in the uk ? debating whether to buy a welder to cut out the rust and do it myself or pay someone but funds not good atm .. 😕 cheers in advance Paul
stants Posted April 23, 2017 Posted April 23, 2017 250-400 a side depending on where you take it really Sent from my SM-G930F using Tapatalk
Paul888 Posted April 23, 2017 Author Posted April 23, 2017 Thanks ! appreciated i'll do it myself then especially as the other side is just starting to bubble now ..
savage bulldogs Posted April 23, 2017 Posted April 23, 2017 If your on f.b have a search for "automotive repair panels " as the sell good quality gc8 arch and sill repair panels [emoji6] Sent from my SM-G900F using Tapatalk
R4bmcg Posted May 2, 2017 Posted May 2, 2017 Anyone know where to get inner rear arches ? I have searched high and low but to no avail
savage bulldogs Posted May 2, 2017 Posted May 2, 2017 Let me know if this link to the Facebook page works , if not I'll try to screen grab some contact details off there . https://m.facebook.com/Automotive-Repair-Panels-424084321262541/ Ray is a helpful fella and well into his scoobies [emoji6] Sent from my SM-G900F using Tapatalk
Elephant Posted May 3, 2017 Posted May 3, 2017 Just got mine and it has a few bubbles on one side is it a major issue ?
Tidgy Posted May 3, 2017 Posted May 3, 2017 1 hour ago, Elephant said: Just got mine and it has a few bubbles on one side is it a major issue ? they go from the inside out so if visible will be bad behind
Elephant Posted May 4, 2017 Posted May 4, 2017 Just took arch liners out and had a good look with a torch doesn't look pretty
savage bulldogs Posted May 4, 2017 Posted May 4, 2017 I spent quite a bit of time cleaning and painting my inner arches on my 94 sti . Even though I've kept the outer and inner arches clean it's started to bubble on the drivers side rear [emoji15] After investigation it's being caused by moisture in the boot being trapped behind the boot liner and sitting on the rear arch/ chassis leg [emoji57] Sent from my SM-G900F using Tapatalk 1
Paul888 Posted May 4, 2017 Author Posted May 4, 2017 That is clean lol i checked mine a few months back and cleaned out the crud and sprayed the inner arches with rustproofer, just caught them in time but unfortunately the outer arches have now gone on one side bad and just bubbling in the other ... i've bought a mig welder so will cut out and replace in the summer when it's warmer and drier .
