BC coilovers
Hi lads does anyone know if a set of said coilovers from a 2006 sti fit my 2004????  I know they have different pcd 114 as opposed to my 100 but why would that make the fitting different or is there a difference elsewhere?
it's like trying to fit a set of 114 pcd alloys on a 100 pcd hub... they won't fit... not compatible
I know the difference between classic and bug onwards is the hub is thicker where it slots into the bottom of the strut.
If yours is a wrx it will run r160 hubs which are smaller than r180 hubs used in the bug onwards sti .
Mayne look on the b.c website to see if the part numbers are different[emoji6]
Thanks very much lads I was thinking it must be to do with the hubs. 👍👍👍
