Need help I don't no what's wrong with my subaru
Hello guys I have a 1994 Subaru impreza wrx automatic.I have put her into drive and she is just nor moving just reving.I just don't get the problem I put it in reverse and 1,2,3 and n and park and they all do the same is that gear box or talk converter I have oil coming out of my drives haft also.is that the seal.
Does sound like a torque converter issue ,seeing as it won't change gear "automatically " and leaking fluid .
Unfortunately probably the only way to find out exactly what's wrong would be to remove the gearbox and inspect it .
As it could be something simple like a linkage and driveshaft oil seal or more expensive like 1 of the hydraulic valves ect .
If it's leaking oil there is a chance that is your only issue,
