6speed sti gearbox into Wrx hatch
Afternoon gents, is it possible to fit a 6 speed box form an sti hatch into a wrx hatch. Straight swaps?? TIA
Yep , the 6 speeds are a straight swap for any classic , bug , blob and hatch 5 speed [emoji106]
All you need is 6 speed box , cradle , prop , gear linkage and gear stick . The 5 speed clutch,fly , starter ,slave and driveshafts are all compatible.
You can even keep your 5 speed diff and rear shafts if you find a 6 speed thats the same ratio as your existing 5 speed [emoji6]
  • 5 months later...
Bit late but cheers for be response mate, I’d look to buy the full lot anyway diff included. Gearbox is holding up as it is anyhow so it’s been out on the back burner
