Fuel starvation?
Hi all and thanks in advance for any help.
I have a problem with car cutting out when hard cornering it seems like fuel moving away from the pick up in tank causing fuel starvation for a second or 2, sure I've read somewhere about it being a problem with classic impreza but can't find it so apologise if it's been covered loads before. The thing is can it be cured.
Thanks Neil
Yeah the classic tank has a hump in the middle to clear the diff underneath , so hard right hand corners can cause fuel slosh and cause fuel cut .
You can fit a swirl pot and 2nd "lift" pump or.. just dont give it beans round a right hander with less than half a tank [emoji6]
Thanks savage
Will be a swirl pot at some point in the future. Will add it to my ever extending list :rolleyes:
