Hello from Germany :)
hi im lucas from german.
in 2015 i owned my first car. a subaru impreza wrx 2004 from UK.
now my gearbox is damaged. it was the third gear... now im doing a big modification.
i want to swap my gearbox to 6speed and i want to install the golden brembo brakes 🙂
the most of the change has happend but now the modification stops. an abs ring from the "new " axis is broken. and now i need a new one but i cant find anything in germany. subaru dealers in germany cant or dont want to help me. i need the partnumber or someone who has got some to sell.
the diameter is about 14cm outside, 12cm inside and is fixed with 5 bolts.
i hope you guys could help me and sorry for my bad english. i hope it will get better when im here now 😄
Welcome to the club Lucas, try Luke at importcarparts.co.uk he should be able to sort you out if they don't have it in stock they will be able to get it 👍
Wotcha and welcome - Your English is way better than my German - where are you located as I spent quite a bit of time in Düsseldorf & Duisburg?
