omex rev limiter.
has anyone fitted an omex rev limiter on their car.
i have fitted one and cant get it to work.
dont know if i have wired it up wrong to the coil packs.
there are four wires. red. black. blue and black with a blue stripe.
i know the black is positive but dont know what the others are.
Yes, don bother, it's a pita, dosent work right(pushes through the limiter) buggers your lambda sensors.
Loud pipes save lives
is there something else on the market that will do the same thing.
Yeah, wait till you get it remapped and get the mapper to-do it [emoji16], it's a 100% better option
What are you trying to achieve? the ecu controls everything, no need to run anything else untill you get to the point of running big power.
All this bolt on crap is a waste of money and half the time damages the engine.
I think it depends on the model of Revlimiter you have. The ones i have see have the following:
Red - Coil Positive (power)
Blue - Coil 1 Negative
Blue - Coil 2 Negative
Black - Earth.
(some come with an extra cable - Orange - Remote button)
Also if you want it just for pops and bangs, i heard it is best to remove the cat 😛
its the wires going to the coil on the car i cant work out. dont know which wires do what.
Omex will tell you the same they told me, Subaru is not supported by them and the unit dosent work on them
You can hear it here on mine, even tho the limiter cuts in it pushes through.
If your determined Todo this then the 2 wires for the coils you have a splice into with one way diodes then join them together
  • 7 months later...
I’ve seen the YouTube videos of the omex working on yours, any chance you could draw a diagram of how you wired it up to work? Or a video demonstration of the wiring maybe
TIA
  • 7 months later...
So does any one have a diagram for wiring up the omex to the Subaru?
