2002 WRX Dimmer Questions
Hey all, first question post!!
I have a 2002 WRX, and am wondering what the dimmer does on the stalk.
I thought it dimmed all the gauges and the HVAC, but I have replaced a bulb, and since that the dimmer only seems to do the clock, the odometer and the ambient temperature. Is this right or should it do the speedo/tach etc as well?
Second question, if it is supposed to do that what should I be looking for to fix? I was considering LED replacements but don’t like the fact it won’t dim as I do a lot of night driving.
Thanks in advance!!
Hi mate had a 2002 wrx myslef as my first scoob lovely motors. Im sure its only there to dim clock/odometer ect as you stated, basically all non essential info. Not sure if the bugeye does but my blob dims the stereo if i hold its power button in aswell. If in doubt however = owners manual.
Thanks Ross, I checked the manual but it just says instrument panel, the issue is mine doesn’t do all instruments, just the bits I said (including clock). I’m sure it did the whole lot before I blew the clock fuse (now replaced) being stupid.
I’ll have to find a bug close by and check.
Mine only dims the same as yours so im sure there is nothing to worry about mate
Ah cool, thanks Ross, mind put at ease. It’s one of those odd things that I was sure it dimmed more before I blew the fuse, but just the mind playing tricks.
Have a good weekend, I’ll continue to tinker with some other bits...
