Boost issue 0.5 bar. Yawn!
Hey people, I’ve got an Impreza classic wagon and it’s never boosted correctly, I've put a gauge on it and it’s only boosting at 0.5 bar. I’ve had the inlet manifold off and checked all the pipes, not fun, didn’t find a single split pipe. Any ideas? It also has an annoying hesitation at gentle throttle. Any help would be appreciated to make it go how it should!
I guess you can get some boost controller, still by stock I believe they came like that... 😄
My v3 97 UK turbo only ran 0.6 bar as standard,  so it might not be a intake air leak causing the problem.
What model /version is it ?
What Ron fuel do you use ?
Could try cleaning the maf with brake and clutch cleaner , just be sure that the maf is dry before refitting and dont touch the element (wire) , as they're very fragile.
A self ECU code check and reset might help too
