Check Engine light
Hi all I am a little confused about my engine light. It comes on for a few days and then for some reason it goes off? There doesn't seam to be any change to the car or the way it drives. Any help would be welcomed
Sarah
You could always try a reset by disconnecting battery for a bit. Then the ecu will re learn and maybe the code will stop. It may run funny for a few miles while it learns. If 2005 get a cheap code reader and find the code.
Thank you guys . Its a 2005 so im off to get a code reader
Sarah X
