STI Genome gauge - LED problem
Hi Guys,
Recently I encountered following problem with one of my STI Genome gauges :
Half of the gauge is not lightning up.
The strange thing about it, is that sometimes it lights up again, but then after a short time it goes out again.
I checked the electrical wires at the back of the gauge & the control unit, but everything there seems to be OK.
Can anyone help me with this problem or has encoutered the same situation and has got a solution for this (except from buying a new one).
Any help is much appreciated!
As part of it is lit and the gauge still functions I would say your rear wiring connectors are fine. It would point to a break where the led mounts the PCB (as it is intermittent) or worse a component that supplies the voltage to the LED is on the way out. As these will all be surface mount components it is not impossible to repair but a large magnifying glass and steady hands is a must have
